Maintenance question
Old 07-18-2010 | 08:52 PM
HOG_0308's Avatar
HOG_0308
Default Maintenance question
When going around my bike with the torque value book tightening things down… I was wondering, if the bolt has lock tight on it, tightening down to torque value, wont that break the lock tight and encourage the bolt to come loose over time?
Old 07-18-2010 | 08:58 PM
dawg's Avatar
dawg
When you say tightening down, do you mean you simply put the torque wrench on it and tighten it until it clicks/reaches torque or are you loosening the nuts/bolts and then re-tightening them until the torque is reached?
Old 07-18-2010 | 09:01 PM
rickf28's Avatar
rickf28
Seems like it would.
Im thinking that if the bolts where properly tightend to begin with (with lock tite) then the torque wrench should click without it turning anyway.....
If the bolt does turn (not properly torqued) and you are really concerned about this then take the bolt out and clean, put new Loc-tite on and re-torque.
Just a suggestion is all...Rick
Old 07-18-2010 | 09:03 PM
Ronp42's Avatar
Ronp42
Account Retired
In the service manual torque specs, set your torque wrench to the middle setting. If your bolts haven't loosened any, you should not feel it break loose. If you do, Take the bolt out and apply blue loctite and retorque it.I've found after applying loctite and torqueing a bolt, it will take more torque to break it loose. After you finish with your torque wrench, back it off so the spring has no tension on it. Saves your torque wrench!
Old 07-18-2010 | 09:05 PM
Ronp42's Avatar
Ronp42
Account Retired
Wanted to add, never use your torque wrench to loosen a bolt, only to set torque!!!!
Old 07-18-2010 | 09:13 PM
HOG_0308's Avatar
HOG_0308
Thanks guys, i really appreciate the info. I'm going to go with setting the torque wrench in the middle of the setting. Thanks again guys
Old 07-19-2010 | 12:01 AM
mjsawatzky's Avatar
mjsawatzky
Is there an actual torque value book or are you referring to the repair manual?
Thx
oldtoad
General Topics/Tech Tips
04-04-2019 07:21 PM
dFREDb
05-30-2010 06:07 PM
wolfydude
02-21-2009 01:04 AM
straydog13
Ironhead
08-03-2008 01:47 AM
twilliams
06-20-2007 11:16 AM
