To Tweeter or Not to Tweeter??
I just installed the J&M 7.25's with the Elf 2125 amp on my 09 FLHX. I'm thinking of adding the tweeter pod. I've done a search but it's painfull to read all of the posts on speakers to find anything about the tweeter pod.
I'm just interested to hear what people think of the tweeter pod with a similar setup. Is this something I'll notice a big difference with or not?
Thanks
Banks
Thanks
Banks
I had Hogtune speakers and the tweeter bar on my 09 before the upgrade to an Arc Audio amp and their 6 1/2" component speakers with a Sony marine head unit...I felt the tweeter bar helped the hogtune speakers a little but not worth the cost plus you have to drill 4 holes in your inner fairing and once the tweeter bar comes of the holes need to be plugged... and it's not an invisable repair, plus hogtunes doesn't use a crossover to project the frequencies each speaker can handle they give all the speakers the same shot and simply kill the frequencies that are out of range...makes for a higher signal to noise ratio..If you are not going to get a true component speaker complete with crossovers I would pass on the tweeter bar...
The HT tweeter pod, due to its location (higher and closer than the fairing speakers) is very noticeable when added. Whether that's a good thing or not seems to my ear to depend on the music I'm listening to since it can, and does, overwhelm whatever base or mid-range is in the music. If I get ambitious I'll see about installing a gain control or potentiometer to allow adjustment of the tweeters in the pod to turn down the volume of the tweeter pods when it does overwhelm the sound from the fairing speakers.
I have Infinity Reference 6.5" speakers, Arc 125.2, Hk head unit, and the HT pod.
Suggestion: Ride the bike with the new speakers you have and see if you like what you have.
