Manual says should be in 6th gear at 55 is this right?
Old 07-19-2010 | 10:56 AM
iclick's Avatar
iclick
*** Deleted double-post ***
  #62
Old 07-19-2010 | 10:58 AM
iclick's Avatar
iclick
Originally Posted by cezariomaia
You north americans are a lucky people... here in Brazil, by law, we have a minimum of 24% ethanol mix...
What many don't know is that engines can be made and tuned to run optimally even on 100% ethanol, and you can see the results in alcohol-burning racers. The problem is they can't run well on both, as with pure ethanol you need very high compression (12-13:1) among other things. When you start adding ethanol to a typical gas engine it will not run as well or as efficiently.
Unfortunately, your Harley in Brazil is likely little different from ours, so you have to deal with the performance issues of running E24. BTW how do they run on this mix and are there any differences that you know of between our bikes and yours? Are they US-spec?
  #63
Old 07-19-2010 | 11:10 AM
cezariomaia's Avatar
cezariomaia
Brazil is the 1st country in development of vehicles technology for using ethanol. Our cars uses any mix you put in the tank. They self adjust automaticaly. Gasoline have an adition of 24% minimum of ethanol. The trouble are with imported vehicles. Ethanol corrodes fuel lines, carburetors, injectors, intake manifolds and so on. Imported cars have to be "tropicalized" to handle our fuel. But, fortunately, the fuel octane ratio are higher with this mix. No pinging whatsoever.
By the way, we only feel a almost unperceivable loss of power in our bikes, comparing with what we use when we are in the USA, and ours "drink" a lot more fuel...
  #64
Old 07-19-2010 | 01:05 PM
Harley_RN's Avatar
Harley_RN
Originally Posted by lowflyer
My `9 RG likes 6th after 65mph
same here... I don't go into 6th until I'm at or above 65. I usually set my cruise control for around 74mph. I agree with the other posts that you should let your engine dictate when you go into 6th gear.
  #65
BlockHead96's Avatar
BlockHead96
Bottom line is, Ethanol sucks! Since the increase percentage here with summer formulation, my wife has lost 1.25 MPG in her car. I'm curious if an Octane booster might not help.
  #66
Old 07-19-2010 | 01:07 PM
BlockHead96
That's all well and good, but when you get there and roll on the go, it shouldn't ping..
  #67
Old 07-19-2010 | 01:08 PM
HOG_0308's Avatar
HOG_0308
my 08 Ultra, nothing below 65 for her, or she bogs down
  #68
Old 07-19-2010 | 01:49 PM
Baffler1's Avatar
Baffler1
Originally Posted by tmair
i leave mine in 5th all the way up to 80 or 90...but then again i don't have a 6th!
Terry
yeah what he said -
  #69
Old 07-19-2010 | 02:04 PM
hotrodsandharleys73's Avatar
hotrodsandharleys73
I have no problem @ 60 in 6th with mine, especially after the exhaust and A/C change.
  #70
Old 07-19-2010 | 04:33 PM
t. sawyer's Avatar
t. sawyer
07 sg 65 or better or the top of the engine sounds like its going to fly apart. I don't like that sound.
Kroozeabout.
Quick Reply: Manual says should be in 6th gear at 55 is this right?
