Manual says should be in 6th gear at 55 is this right?
Old 07-17-2010 | 06:59 AM
JayStronghawk's Avatar
JayStronghawk
Thumbs up
Originally Posted by JimTJr
I shift when it needs it,,, different circumstances need different gears! Use your experience to shift, He!! remember when no Harley had a tach? You had to use your ear!
Likes this answer ...
Old 07-17-2010 | 07:02 AM
Notgrownup's Avatar
Notgrownup
Originally Posted by 2nd Mike
Only if coasting down hill.
Ditto.
KutenFLHX's Avatar
KutenFLHX
I let the sound and feel of the bike tell me when to change gears. If I'm cruising along at 55-60, I will switch to 6th gear.
Old 07-17-2010 | 07:20 AM
Wingnut51's Avatar
Wingnut51
Originally Posted by bikes
If the manual says it's ok to be in 6th at 55, I guess it's ok. I try to keep the tach at a minimum of 2,000 rpm's. 55 mph in OD isn't bad on smooth and flat road.
I'll do it if I can maintain a steady speed on a flat road but I'll drop down to 5th if I approach any hills or if I have to accelerate for any reason.
Someday I'm going to have to add a tach so I can see actual engine speed.
Old 07-17-2010 | 07:53 AM
smithbrl's Avatar
smithbrl
I can shift at 55 with no problem. Acceleration is a little sluggish but no lugging,knocking or pinging. I usually shift at 60 because acceleration is better. This is on a flat road. If climbing hills then whatever it takes to maintain 2500 rpm. Shifting through the gears at 2500 comes out to about 20,30,40,50,60 mph, from what I remember. About the only time I'm over 3000 rpm is when I miss a gear.
I guess I may get over 3000 on the interstate when I open it up a little bit-don't remember.
Old 07-17-2010 | 08:04 AM
cogener8's Avatar
cogener8
60 to 65 for me. Anything lower than 60 and the RPM's are dropping under 2K.
Old 07-17-2010 | 08:18 AM
troop's Avatar
troop
I don't pay a whole lot of attention to the tach on my 09 but I think 60mph in 5th is about 2400rpm? Looking at Tq charts, this is about where the good torque is picking up. Wouldn't this be the ideal rpm range for pick-up and mpg?
Old 07-17-2010 | 08:20 AM
cass's Avatar
cass
I think i varies depending on condidtions and attitude. If you're chillin, @60 in 6th is ok. If you're into it, might not ever make it there.
cass
Old 07-17-2010 | 08:32 AM
DaveMK's Avatar
DaveMK
I thing mine would stall if I put in 6th at 55mph.
Old 07-17-2010 | 08:49 AM
RodeDawg's Avatar
RodeDawg
Originally Posted by hover
I Dunno, my 09 will pull a hill at 60mph in 6th riding 2up, it aint luggin...as long as its over 2000rpm its good.
Agreed. No problem as long as engine is 2000+
Quick Reply: Manual says should be in 6th gear at 55 is this right?
