NEw to the forum as of today. rebuilding a wrecked 07 RD with my son.
Does anybody know if the wheels of the 2009 or 2010 RD will fit my 2007? I like the new 2010 wheels and I found ton on eBay.
Thanks
The front wheel will fit if you change the bearings, the rear wheel is too wide to fit. If you look around you should be able to find wheels from someone that's upgraded to aftermarket wheels, I'm pretty sure 02-07 will fit, depending on the style of wheel you're looking for.
..... welcome to the Darkside, Rob, what a great project to take on w/your son !
...... i know the 10' wheels are larger around than the '07s, but you'll need someone more knowledgeable than i to completely answer that question.
........ Welcome to the forum. check Roadglide.org too
I have the wheels off my 07 roadglide you can have them both for $250 if you want. i need to get them out of the garage
I put a 10 on mine i will tell you it a Pain but it looks so good.
You can do what I did and use a '10 front wheel and then I found a 07 street glide wheel to use on the rear. If you use the '10 front, you need the axle, spacers, bearings and wheel for a '10. If you just swap out the bearings to the 1" style and use the stock axle and spacers you wont like the end results.
