Rear tire sliding in rain
#51
Now are there better ones out there? Sure, Probably so. But the stock ones are quite adequate.
#52
Well I have about 3,000 miles on my stock tires. Maybe 140 of those in the rain. Other than turning a corner at an INTERSECTION. I experienced a very slight slip with my wife on it,,(She about sqeezed me in half, didn't say a word) but it didn't do much other than maybe scoot out a couple inches on me. I rolled off the throttle and it bit again. She asked me about 5 miles later,, did you loose traction back there? I said, uh,, yea, a little.... she just hugged me a little and said,, "good save"! Man I have a great wife! I assume that in the middle of an intersection, FRESH rain, I had hit oil in the center,, still sure that's what it was. These tires MAY not be the best out there, I won't likely go back with them, (I also like Metzlers) But they are certainly fine,,, at least when new!
Braking in the rain, especially without the Abs,, (I love it!) you really have to be careful to balance. If you put too much on the front, the weight transfers forward, and the back will get light,, personally I use a little more rear in the rain than I would on dry pavement, you can control how much you give it easier.
I don't think it's the "lack of weight" over the tire.. really I think you just messed up. NO OFFENSE meant at all, but I have a few more miles than 20,000 total experience,LOL,, about 15 times that, and have only taken the Basic MSF course way back in 93 so I could ride onto the base I worked at. (Not the experienced one, I would LOVE to take that, and may this summer)
Not KNOCKING your experience ok? PLEASE don't take offense. But there is nothing inherently wrong with these bikes and the stock tires IMHO.....
So you are the other street glide at work....
#53
Quote:
Originally Posted by Wecroft
Guess you're saying JimTJr is wrong.
You have both sides of the argument in quotes. The tread is the determining factor when it comes to hydroplaning. Just ask any NASCAR driver. No tread, no run in the rain. The sissy guys in the open wheeled cars change to a treaded "rain tire" at the first drop of moisture.
you said " Wider tires hydroplane easier than narrow tires " did you not? that's not correct. tire width is not the determining factor in evacuating water. having road raced for years i would prefer a 190 rain tire over a 150 slick, you?
Hey Dave,
Maybe basic laws of physics work differently north of the border but in the rest of the world wider tires do hydroplane easier than narrow tires that have the same tread or no tread at all. It's simple, if you support the weight of an object (the motorcycle) over a larger surface area (wider tire), the downward force per square inch is reduced, thus traction is reduced.
Better yet, let me put you behind my boat on a pair of WIDE water skis. Then let's try it with NARROW snow skis. After being dragged a mile or two I'll bet the farm you'll change you mind
I don't give a **** if you raced with snow chains, you're getting shitty because I agree that having tread on wet road is better than having a stock MC tire with very little tread to remove water. WTF? Re-read the posts and figure out which way you want it.
Now, stop quoting two people at once.
Hey Dave,
#54
#55
no probs yet but i will say coming from a 04 fatboy to a 09 street glide which is much more weight i felt like i kinda had to re learn my driving habits far as braking the glide, much different feel. the fatty i could roll up up fairly fast and still stop at a light with no probs. the glide i need to start braking much sooner due to the weight i think. might need to just slow things down a bit sooner when braking.
#56
Now quit drinking that cheap Canadian crap and mix up a Capt Morgan & Coke.
#57
I have about the same experience as the OP and I have the same ride (an 09 street glide, but with the same tires as the OP because of the cupping issue with the 407's on the front). The only difference is 90% of my experience is on the street glide, of which about 2500 miles have been in the rain. I have never had anything close to what he describes, but I would suggest the bike is fine as long as the tires have been broken in ( I would strongly suspect this is the issue).
#58
I'm very relaxed, but my original statement is still true WIDE hydroplanes easier than NARROW. Less down force/square inch = easier to ride up on a sheet of water. Both width and tread design/depth are equally important factors. I haven't "come on board", I was there from the get go.
all good, ride safe.
#59
#60
The tires on my 09 ultra are lasting a lot longer than on my
07 But they twice in 25,000 it felt like they broke loose
In a corner in the rain That never happened to me before before and I have been riding for a few years. So my
Question is what are the stickiest tire they make for a 09
Ultra ??? The ones on there I sure are fine but I would
rather have less wear more sticky
