pc-v
Location: CHILLIWACK B.C CANADA: have a u.s shipping adress
pc-v
stopped at the dealer on way home from work tonight to see if i could get my cruise enabled... serv mgr says hey i'll do it rt now for you and rolled it around the back into the shop..a 20 min. later a mechanic comes out and says all done,we checked for fault codes too and installed the latest update to the ecm from calibration id # 32935-08d to 32935-08e..my question is this ... he was unaware that i had just installed the pc-v ...do i need to reinstall my map to the pc-v or no?..he also found "historic" codes p0131 and p0151,witch aparently translate to both oxy sensors low/lean??
I wouldn't do it as a permanent solution, as the configuration of the two ECM's are different. If you bought the PCV from Fuel Moto give them a call for a more definitive answer to this question, but I think in general you would be ill-advised to use an '09 map in an '08 or vise versa. I also think this would apply to any two year models.
