PCV TPS settings
PCV TPS settings
Was changing map last night on my 08 Ultra, and noticed the throttle position was not at zero at idle. It was like 32%.
Re-set to zero, probably was affecting gas mileage and performance.
Question is how do I know what the top end should be set at?
Is there a procedure to re-set that or does this HAVE to be done on a dyno!
Answer from Fuel Moto:
Hello, the base voltages are .684 Min/ 4.527 Max. This will very much influence what the PC-V and AT are doing as this will swing the entire map. We have not needed to adjust the Max voltage in any PC-V DBW applications so just put in the 4.527 and you will be fine and then check the Min voltage when the bike is up to operation temp and simply use the current voltage.
Thank you.........Jamie
Fuel Moto
2215 Kelbe Dr
Little Chute, WI 54140
Toll Free Sales/Tech 1-877-729-4754
Specializing in EFI tuning and Exhaust components
Fuel Moto websites: www.fuelmotousa.comwww.jackpotmufflers.com
Thanks Jamie
Fuel Moto
2215 Kelbe Dr
Thanks Jamie
perryross
06-15-2012 08:36 AM
