Hill Country Custom Cycles
I dont have abs, but my bars are from HCC. I bought the whole kit ready to go. Controls wiring and all that was done. From what I have seen the abs isn't much more difficult to switch out. If you have any mechanical skills you should be ok. I dont have any skills and was ok with the help of a buddy.
I put a 16" kit on my RK last year. I have helped 3 others do kits from HCC. None of the bikes had ABS but I recieved a bad brake line from the factory and they next day shipped a new one to me. It's a great kit and fairly easy to install. I had a problem with bleeding the dual front discs and bought an air powered brake bleeder for $30 and got them working in minutes. Buy from this company.
I am doing my 09 abs right now. Nothing different from any other bar install I have done other than some extra brake line. I have installed just about every brand brake line out there and they have all sucked. The splitter at the forks for the front brake lines either wants to leek or is made of a huge chunk of metal that sucks. I ordered all my lines this time from Dr. V Twin and Shawn talked me into going with Magnum black pearl lines. The magnum brake lines are a 3 piece system for the abs. You have 2 lines going from the master cylinder to the abs module. One comes from the module to inside the fairing the other top line hooks to this one with a compression style fitting and then goes up the master cylinder. The reason for this is so you can change your bars and only have to change the one short top line which will save you money. Now for the bottom line it is a one piece system that goes from the module all the way to the calipers it bolted up just like the factory with no worries about leaks. I another thing I would suggest is that you change out your riser bushings with some from alloy art. My bike is the first one I have done the bushing swap on and boy is it going to make a deferents.
I will report back this afternoon how the bleeding goes and if i have to take it in to get it digit teched or not. I am going to do it like I have all the others and hook everything up and hook a 65cc syringe and rubber hose to the bleeders and start pulling fluid through until I can't see any air coming in.
Thanks for the replies, please let me know how your jobs go. I had not planned on changing the lines from the ABS controller to the calipers though. I really don't care too much about what the bike looks like as after 11 HD's and countless thousands on mods, this one is staying mostly stock. The reason for the bar change is comfort not looks.
Back to the bike subject for ABS make sure you have 2 bottles of brake fluid on hand I had to stop and go pick up another bottle. Which I probably wasted more than most I just kept pulling till air stopped showing up.
