4-point Docking Kit ?
Recently installed 4-pt docking hardware kit on my 2009 EGC. Agree w/other comments re: instructions not very clear. Question is does the chrome rear frame extension cover stay on under the 4-point brackets? I can't see how it could - not enough holes for bolts, but the instructions don't say remove it. I left mine off... just installed the brackets. Thanks for help.
Step 1 of the instructions is to remove the screw holding the rear of the chrome cover in place. Just the screw. The cover stays on the bike.
There are 3 screws holding the docking assembly to the bike. 2 go in the holes that your tourpak mount was bolted to. (If I recall correctly) The third goes in the hole you should have removed the screw from in step 1.
Can anyone send a photo of this??? Thanks.
Ok so you went from rigid mount tour pak to a detachable mount? The rigid mount tour pak like on EGC and Ultra have different chrome strut covers. If your trying to mount detachable mount you either need to drill couple holes in your existing strut covers or buy some Street Glide chrome strut covers. If you buy the entire detachable tour pak conversion kit new strut covers are included. Strut covers are 47502-09 & 47504-09.
Ahhhh... there's the answer - I did go from rigid tour pak mount to detachable, didn't buy the entire kit, just the 4-point and the tour pak mount. So, I'm missing the side covers that have the extra holes! Was driving me crazy.
Thanks acchd.
