Can I install ACR's on HQ heads?
The ACR has to have the same pressure release hole, unfortunately, it's not in the side of it.
The ACR pressure release hole is drilled in the head.
It releases out the exhaust port.
Without removing your heads and having a hole drilled to release pressure, I don't see how it can be done.
I remembered seeing pics of the heads, with the holes, off a motor.
It was Phil's 124 thread.
In the very first post he shows the chamber of a head.
The tiny hole you see is the pressure release hole.
There's another pic on here somewhere of the exhaust port...it shows the hole exit.
I believe that was Phil's pic, too...but I couldn't find it.
Anyway, here's the link to the thread showing the head chamber with the hole...
https://www.hdforums.com/forum/touri...ect-124-a.html
