06 Road King Custom With Cracked Y Header
Old 07-10-2010, 06:46 PM
OddJob's Avatar
OddJob
OddJob is offline
Default 06 Road King Custom With Cracked Y Header
I have a 2006 Road King Custom, and as I was riding today and thought my bike sounded a lot louder and crappier. I got off the bike and noticed that the Y exhaust pipe on the back cylinder was cracked, so I have a couple of questions.
First off, what kind of pipes are good replacements? I would like duals if money can support them, but as I am short on funds, are there any pipes that I can put on without having to get a tuner for the FI? I had originally planned on doing all this over the winter with a tuner, new pipes and possibly new air cleaner, but this is kinda unexpected. The mechanic I usually work with recommends Vance and Hines or Thunderheader, but will either of these work without a tuner? Can I retain stock mufflers with new pipes, or are they usually matched sets?
Secondly, I have a friend with an 08 Road Glide. He replaced his pipes and has the stock ones still. Being that his bike is a 96 and mine is an 88, will those pipes work until I can get some new ones in? Any feedback would be greatly appreciated.
Old 07-11-2010, 09:59 AM
wink2206's Avatar
wink2206
wink2206 is offline
Default Cracked pipe
Hard to say about the pipes requiring a tuner. Some say you need one, some don't. I can say that a Y-pipe off of the '08 will fit your 88". I replaced my buddy's '03 pipe with my '07 pipe. His was cracked really bad. All you need is the plug for the o2 sensor and new gaskets.
Attached Thumbnails 06 Road King Custom With Cracked Y Header-crack-kills.jpg   06 Road King Custom With Cracked Y Header-07-pipe-installed.jpg   06 Road King Custom With Cracked Y Header-whole-new-pipe.jpg
Old 07-11-2010, 10:16 AM
tenn.vol.'s Avatar
tenn.vol.
tenn.vol. is offline
My sons 01 RK, has had his welded twice in 57K miles.....Tenn.Vol.
Old 07-11-2010, 12:11 PM
sargek's Avatar
sargek
sargek is offline
Nice pics - and I thought mine was bad...mine ended up twisting and breaking during removal so welding it was not an option.
Old 07-11-2010, 12:54 PM
dredy2g's Avatar
dredy2g
dredy2g is offline
Full Sac will do the trick, they have a true dual conversion kit that allows you to use ur stock or slip on cans and doesn't require remapping and it cost I believe a couple hundred pennies. Just do a search on Full Sac performance.
Old 07-11-2010, 03:48 PM
OddJob's Avatar
OddJob
OddJob is offline
Well, I started digging into it. The pipe not only cracked, it came out in two pieces. I took the pipes off the 08 Road Glide, plugged the hole for the O2 sensor with a bolt and got them up and running. it sounds and runs so much better now it's unbelievable. I have only had the bike a few months now, and I have a feeling that this was a problem when I got it that just got worse and worse over time.
So now that gives me some time to actually do the new pipes right. I had planned on getting a Power Commander or something of the sort when I got new exhaust. I will still do that over the winter and for now I can still spend all my money on riding it. :-)
Old 07-11-2010, 04:22 PM
Mike's Avatar
Mike
Mike is offline
I had the fullsac conversion on my bike, and just eliminating the y-pipe made it sound so much better, I can't believe I waited as long as I did. If you go that way, you'll keep most of your stock head pipes, and if you buy the fullsac on ebay, they can be had for about $150. Harley Goodies now has a 24" straight heat shield for the right side, and you can have the whole thing done for not much more than 200 bucks.
Alternatively, you can watch the classifieds here on the forum, or on ebay and get a complete dual exhaust or 2-1 system for not a whole lot more than that if you get lucky.
Old 07-11-2010, 05:53 PM
NE2I's Avatar
NE2I
NE2I is offline
2up for Fullsac! super heavy duty rear pipe! mine works great and was really easy to install. The only thing i did was add a new straight samson heat shield
cause the old one was really beat. With my Rush muffs it really sounds good!
Old 07-30-2010, 10:40 PM
wink2206's Avatar
wink2206
wink2206 is offline
Default Happened again
Just an update to my earlier post. After replacing my buddy's pipe with the one from the '07, it has cracked again. I am thinking a motor mount is bad or something. The mounting bracket for the y-pipe attached to the bottom of the engine was cracked as well before the change. I welded that too. Just keep that in mind before changing to another y-pipe. I am sure that true duals will take care of that problem.
Old 07-30-2010, 10:49 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
Check that front engine mount. Apparently the rubber deterioates and they break.
Quick Reply: 06 Road King Custom With Cracked Y Header
