Car tire ???
Old 07-29-2010, 08:48 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Even the motorcycle tires of yesteryear were shaped like a car tire. Here's a Goodyear Super Eagle, 5.00 x 16, which were run on Harleys. Note the flat shape of the tread.
http://www.debrix.com/v/vspfiles/pho...0305-VT-2T.jpg
  #82
Old 07-29-2010, 08:54 PM
MNPGRider's Avatar
MNPGRider
Originally Posted by RandyDowdy
That tire was ridden with far too much air in it, or it would have worn evenly. Too much wear in center, too much air. Too much wear on outside edges, too little air. Simple as that.
Randy, that tire is in my garage, off my Ultra, and I just took the picture. It ran with the recomended 40 lbs of air for the life of the tire (and should have been changed out earlier). I challenge you to post a picture of your worn out tires, showing worn sides, or "even" wear. Go look at your bike tire...I bet you will see the nubs still on it and a lot more tread on the sides than the center. A tour bike does not lean over that far to wear the sides off. Simple as that.
  #83
Old 07-29-2010, 09:02 PM
RandyDowdy's Avatar
RandyDowdy
RandyDowdy is offline
The ones I have worn out on my Sporty don't wear in the center THAT bad. They might not be dead even, but they aren't that bad. Perhaps there is a bigger difference between a tour bike and a sporty. I just can't say.
  #84
Old 07-29-2010, 10:14 PM
Twinrider's Avatar
Twinrider
Twinrider is offline
Tires will wear like that on bikes that do mostly straight line riding.
  #85
Old 07-30-2010, 05:18 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is online now
Received 7,164 Likes on 3,675 Posts
I have tried the recommended air pressure on all the tires i ran and
I disagree. On big touring bikes i see mostly the middle part flat like this..I am on my 7th tire in 3 years and they all wore like this...The only one that wore more evenly was the Avon and that was because i only got 6000 miles out of it.
  #86
Old 07-30-2010, 07:28 AM
dog155's Avatar
dog155
dog155 is offline
We used to run car tires all the time biggest reason was motorcycle tires were a pain to get.We never gave it a second thought and could not possibly have ridden our machines any faster,or cornered harder with motorcycle specific tires.Anybody that says car tires are not for motorcycles obviously does not know what they are talking about,simple as that!
  #87
Old 08-01-2010, 11:49 PM
gaston 2005 502's Avatar
gaston 2005 502
gaston 2005 502 is offline
Stock worn Avon tires for Boss Hosses wear like that. Also a well used tire as Hosses will smoke the tire, and it doesn't have to be stopped when smoking the tire. Starting a smoker at 70mph through 125mph in first is fun, don't ask how i know. Mine had a 240 avon on the rear when i got it. and it would get squirrely when i would whack it. i switched to a car tire wheel and would not go back. 245/35/18. Smokes quite well too.
Simple as that is not always one way for it to be done.
Darryl
  #88
Old 08-18-2010, 09:15 AM
bagger90's Avatar
bagger90
bagger90 is offline
Originally Posted by Tazzrider
Over the last couple of years, this type of tire thread has become as ridiculous as oil threads...lol
Let's just settle it here:
Naysayers, dig, research, pry, bribe, anything you must to find links to negative testimony due to using a CT on an MC...then post the links here as your ammo for your position. This will at least give you "some" logical "proof" for a closed mind...lol
And, on the flip side:
Believers, do a quick search and post up links to the numerous positive testimonies regarding CT use on MC's.
Believers are a step ahead already, with some videos and a few CT users already chimed in. Like said already, if you haven't tried it, don't have any testimony, video or actual experience, dissin the idea won't fly.
LOL....Nuff said!
AMEN BROTHER
LucyOnBlack
06-15-2013 05:48 AM
rjmac53
03-06-2012 01:19 PM
frenchbiker
11-26-2011 04:13 PM
KylePutzier
09-14-2011 06:25 PM
JG09
06-21-2011 04:05 PM
Quick Reply: Car tire ???
