LED load equalizers
LED load equalizers
Sorry if I am repeating old posts.
2006 RoadKing
Changed turn signal bulbs to LED's. Also changed brake light bulb to LED type. All seems to work properly other than the security light staying on.
Is that the worst problem of not having a load equalizer?
Forgot to mention I have the run/brake converter on the tailights.
2006 RoadKing
Sounds like you may have bought the Kuryakyn stuff (junk). You need an alarm compatible load equalizer. I don't know which run/turn/brake controller you have but if it isn't the one from Badlands, I would send it back and get the Badlands Illuminator with built in load equalizer. It's alarm compatible too.
It's a known fact that when the current drops (bulb out, changed to l.e.d.), the security light will come on. It's not the l.e.d.'s making the light come on, it's the low current. LED's draw about 90% less current than incandescent bulbs and stay cooler.
The Badlands Illuminator has a built in load equalizer that is "alarm compatible". Therefore keeping the alarm light off. The alarm light comes on to warn you that you have a bulb out because the led's are not drawing the "proper" amount of juice. Sometimes, without the load equalizer, your signals will flash too fast too.
