Buffeting
Old 07-07-2010, 05:31 PM
Ben R.'s Avatar
Ben R.
Ben R. is offline
I have found that my helmet also plays a roll in the amount of buffeting I get. My HJC 3/4 jars my teeth a hell of a lot more than my GMAX 1/2 helmet does.
Old 07-07-2010, 06:36 PM
jag1886's Avatar
jag1886
jag1886 is offline
You just need the right windshield and I found that the adjustable lower fairing wings really make a difference.
Old 07-07-2010, 06:38 PM
vistavette's Avatar
vistavette
vistavette is offline
Most of the time its perfect but sometimes on the highway my eyeballs feel like they're going to fall out; usually if its windy. I have a Clearview 9.5 with the recurve that helped a lot. I have an '09 Ultra
Old 09-14-2010, 03:18 PM
longrideshields-1's Avatar
longrideshields-1
longrideshields-1 is offline
Premium Sponsor
All of the above comments are true, I invite you to try the LRS ultra shield, it has the maximum amount of wind clearance to cut down on buffeting.
on other factor that plays into buffeting is your seat and the distance you sit from the inner fairing.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old 09-14-2010, 04:57 PM
gtrplyr's Avatar
gtrplyr
gtrplyr is offline
How does the distance from the inner fairing effect buffeting? Does sitting closer increase or decrease buffeting? Thanks!
Old 09-14-2010, 05:00 PM
BlockHead96's Avatar
BlockHead96
BlockHead96 is offline
Who makes the HD windshields? I have a Compact and want to try a little taller one,
Old 09-14-2010, 05:22 PM
vistavette's Avatar
vistavette
1+ I usually wear my HJC FS3 which has an option of a sun visor or shield. With the sun visor installed I get a lot more beffetting so If I'm getting a lot I'll remove the visor and either go without it or put on the full shield which usually takes care of it. I have a shorter Clearview windshield with re-curve that helped quite a bit too.
Old 09-14-2010, 05:52 PM
Aslan's Avatar
Aslan
Aslan is offline
I'm 5' 10" no buffeting on my EGC with stock shield. With or without a helmet.
Old 09-14-2010, 09:50 PM
cerv's Avatar
cerv
cerv is offline
Sitting closer decreases the buffeting. Usually the strongest turbulences appear in the area where your poor pillion pasenger has her head. Try slowly moving your head from right behind the windshiled to as far back as you cn stretch, and you can easily feel how the wind changes as you move backwards.
Old 09-15-2010, 05:10 AM
Port Dawg's Avatar
Port Dawg
Port Dawg is offline
haven't experienced buffeting on the RK yet (because I haven't ridden it) but once I put lowers on my VTX in the right position - tucked almost up to the bottom of the shield, 95% of the buffeting vanished. I imagine same deal with the RK lowers that you can add. I plan on getting them as most of my 100 mile per day r/t commute is highway
Quick Reply: Buffeting
