progressive touring link....good or bad ??
Old 07-06-2010, 11:33 PM
albertaman's Avatar
albertaman
albertaman is offline
6th Gear
Default progressive touring link....good or bad ??
just wondering how many have used it and are you happy ? make a difference?
Old 07-07-2010, 05:30 AM
stevefxdi's Avatar
stevefxdi
stevefxdi is offline
i was gonna install the touring link but went with the glide-pro kit instead, it made a huge difference in the way the bike handles and stiffened the rear like it should of been from the factory, 2006 roadking
Old 07-07-2010, 07:36 AM
pale340's Avatar
pale340
pale340 is offline
5th Gear
Default Throttle Up
I used the Throttle up stabilizer and I am so happy with it. I have been riding my RKC for over two year now and I could not believe the difference in handling, cornering, and just the overall ride of the bike. I went with this one because of price and some comparisons I read on the internet. I think they all do pretty much the same job. Here is a link.
http://www.throttleupindustries.com/...tabilizer.html
Old 07-07-2010, 07:41 AM
SteveB FLH's Avatar
SteveB FLH
SteveB FLH is offline
Have been happy with my touring link, and yes it does make a difference.
Old 07-07-2010, 07:52 AM
shortride's Avatar
shortride
shortride is offline
Would someone explain exactly where touring link mounts and how it works?
Old 07-07-2010, 07:54 AM
DamifIknow's Avatar
DamifIknow
DamifIknow is offline
Good Definately good
Old 07-07-2010, 08:15 AM
FLHTCU Owner's Avatar
FLHTCU Owner
FLHTCU Owner is offline
It goes on the rear right corner of the transmission pan. You remove the corner, left and right bolt, and use the slightly loner ones supplied with the Touring Link.
Old 07-07-2010, 08:36 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,868 Likes on 2,430 Posts
That big black bracket replaces the passenger footrest bracket on the right of your bike and the other end of the stabilizer link fits under the transmission.
Personally I don't like that brand, because the stabilizer link is shorter than the other two already on the bike. It seems wrong to me not to use the same length. I have a True-Track which has the identical length to stock and is a better engineering solution IMHO.
What does it do? Stops lateral movement in the rubber mounts under those passenger footrest brackets. Harley fit similar stabilizers in front of the engine and between the heads (on front head for recent bikes), but ever since they introduced the rubber-mount touring models in the 80s have neglected to fit them at the rear of the bike.
The swingarm and rear wheel are mounted off the back of the transmission. So if you have felt the rear steer some of us have that is the cause of it. A third stabilizer (there are several brands claiming to do the same thing) takes out that squirming of the rear end and is a great improvement for your bike.
Old 07-07-2010, 09:01 AM
Mike's Avatar
Mike
Mike is offline
I have the Ride Str8, which is almost identical to the progressive link. It installs the same, you replace the right side swingarm pivot cover/passenger footrest mount with the one in the kit, and attach the other end to the transmission pan.
The bike handles much much better. The third link controls lateral movement of the swingarm, which happens when you upset the rear suspension during a fast, sweeping turn. The up and down movement of the swingarm quickly becomes an oscillating movement without some type of lateral control.
It's a good thing, and most of the systems on the market work well, so get the one that seems like the best deal to you.
Old 07-07-2010, 09:11 AM
stro1965's Avatar
stro1965
stro1965 is offline
I'm a satisfied user of the Progressive link. It does what it says it does and costs much less than it's competitors.
Quick Reply: progressive touring link....good or bad ??
