Trailering an '09 Ultra
Ok, I've been through all the trailering threads and can't find the answer I need. I'm looking for an all-around, open trailer that I can use to haul my 09 Ultra to the dealership or accross country safely and securely. Ideally, I'd like to have a motorcycle-specific trailer that could also be used to haul my 42" zero turn mower in for repairs and for other small hauling jobs. Needs to be easily loaded by one person and substantial enough for the long haul. I'm not handy/confident enough to just slap a wheel chock on a 6 X 10 landscape utility trailer and head out cross country, although I know some have had good luck doing exactly that. I've looked at Baxley and Razor trailers and I like the ground-loading feature vs. the ramp load trailers since I will be loading without help. Seems like the trailers I like are all manufactured far away from Ohio, so picking them up is difficult and shipping costs put them way out of my price range. Anybody know where I can find the perfect open trailer that doesn't cost an arm and two legs and is reasonably close to Ohio for easy pickup? And can anyone tell me for sure whether an Ultra will fit on an 8 ft. trailer?
I've had two baggers on a 5 X 10 utility trailer for about 3000 miles with no issues. Took a little doing to get all tied down and secure, loading was easy with the built in ramp.
One bagger would have been too easy,
http://www.bigtextrailers.com/pdf/30sa.pdf
http://www.bigtextrailers.com/#
Big TEX 30SA with upgrade on the tires
Note, that was a one time deal 1500 up and 1500 back.
Try Northern Tool, Lowes, Home Depot as well. They all sell trailers.
I have one from Tractor Supply (if you have those in Ohio) I paid $400 for it brand new 5 years ago. Today it sells for $580.
Mounting a Wheel chock takes about 1/2 hour, a drill and some good 3/8 or 1/2 inch bolts. Harbor Freight sells wheel chocks Part # 97841 that are pretty decent for $39 to $59 bucks. Some good tie down straps rated at 1000 lbs working load and you should be fine.
Tie down the front end with two ties and the rear the same. 2 attached to frame or on the front motor guard, on each side and 2 attached to the rear frame/swingarm to prevent the rear from bouncing, again 1 on each side.
I have had one of these for about 4 years now, worth every penny. They will arrange to have them delivered, or make your own arrangements. If you want one person loading, there is nothing better. http://www.adventuresportsproducts.com/
As bdp suggested, a 6x10 trailer would be adequate for the job. I've used a 1' long piece of channel fastened to the deck of a trailer for the front tire. There are lots of trailer manufacturers around here to choose from. A trailer for that kind of job will cost around $600 or less here. If you are going to use it exclusively for hauling the scoot, get a trailer with a ramp style tailgate with tie-downs on each corner.
Let me give ya my tip on the securing of your bike that I always pass on. When I trailer, I use two seperate sets of soft straps and two sets of straps fastened to 4 tie down points just for the front end. Overkill? Maybe, but one of those babies let loose while trailering and you'll wish you had double straps up front.
