Notices
Shifter linkage question
Old 07-05-2010, 01:43 PM
elauee1's Avatar
elauee1
elauee1 is offline
Default Shifter linkage question
2010 fltrx the shifter linkage on the trans end has some play it does not seem loose just wondering if play is normal. The play is towards the tranny.
1000 miles on bike.
Thanks to all in advance
Old 07-05-2010, 03:28 PM
SOCALHD's Avatar
SOCALHD
SOCALHD is offline
Need to be more specific. Are you referring to the linkage or the lever at the trans??
Old 07-05-2010, 03:35 PM
strtarrow's Avatar
strtarrow
strtarrow is offline
The linkage itself is riding on bearings at each end. Not certain if that is what you are referring to but you need to be more specific. Do you mean it tilts from side to side or actually loose? If loose, although not versed on the new bikes you may have a lock nut that is not tight.
Old 07-05-2010, 04:22 PM
SOCALHD's Avatar
SOCALHD
SOCALHD is offline
If the lever itself. The upright one going to the trans is loose and wobbling then you need to check the bolt tightness. This could also cause damage to the slines on the shift shaft.
Old 07-05-2010, 07:05 PM
elauee1's Avatar
elauee1
elauee1 is offline
It's the lever goin g in the trans and the bolt is tight
Old 07-05-2010, 07:10 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
The splines on the shift arm and or the shaft may be worn.
Old 07-05-2010, 07:17 PM
elauee1's Avatar
elauee1
elauee1 is offline
Could it be worn with 1 k miles
Old 07-05-2010, 07:24 PM
1flhtk4me's Avatar
1flhtk4me
No,I would say it's a mfg. defect.
Old 07-05-2010, 07:33 PM
SOCALHD's Avatar
SOCALHD
SOCALHD is offline
This should not move are wobble. Bike is under warranty so get it to a dealer. We haved had 2 bikes in this week with same issue. Owners got lucky and we did not have to replace any parts other than a new bolt. on one the bolt was actually missing.
Old 07-05-2010, 08:36 PM
elauee1's Avatar
elauee1
elauee1 is offline
Thanks to all for the replies
Quick Reply: Shifter linkage question
