Horn problems
Horn problems
I tried a search first knowing this must be fairly common but found nothing that seemed like my issue. A few weeks ago my horn (stock) stopped working. No apparent reason like water which seems to be the most problematic issue. I ended up getting a cheap aftermarket horn on ebay, took my assembly apart, hooked up the replacement, tested it and put it back together. Couple days later I went to use the horn and no sound. Not expecting anything I contacted the ebay seller and he sent me another at no charge. This morning I went to replace the horn, hooked it up to the terminals and it worked. That is until I completed assembly, then just a barely audible grunt. I figured I would try my stock horn just for giggles and it is now working and re-installed on the bike. Any thoughts besides blowing out any suspect water from what recommendations I already read?
