Check Engine Light Codes
I was riding my bike tonite and after I got to 6th gear the "check engine" light kept coming on. It would go off after I slowed down, but then come back on when I sped up again.
I got these codes from pulling them up.
What do they mean?
P0152 Rear Oxygen Sensor High
P1356 Rear Cylinder No Combustion
Oh, yea........2007 Road King..............about 92 degrees outside. Thanks!
What do they mean?
Sorry that I did'nt respond sooner. Glad You found the the problem. A loose wire will sure cause the problem You had. A hardly noticeable miss will set the codes. PS: I was born and raised in Toledo, But I had to get out of the rain, snow and cold! lol And where are You from in Ohio?
Sorry that I did'nt respond sooner. Glad You found the the problem. A loose wire will sure cause the problem You had. A hardly noticeable miss will set the codes. PS: I was born and raired in Toledo,But I had to get out of the rain, snow and cold! lol And where are You from in Ohio?
