kickstand spring.
#41
I like your "rolls of dimes" solution. I just spent over an hour helping a bud put on a new kickstand spring, We put his bike on a HF M/C lift, and had to remove 3 of the four bolts holding the front attachment plate for the spring, in order to have enough slack to affix the spring.
My only question is: Why didn't you provide this KISS method earlier? (:
#43
I have heard that trick before using pennies but since everything on HD costs more, dimes have to be used
#44
If a spring remains under tension (force) where the stress in the material is lower than it's acceptable limit of elasticity, it's OK. Otherwise we would destroy our jiffy stand spring by over-stretching it with a few maneuvers.
karz10
05-21-2017 06:57 AM
