kickstand spring.
Old 09-07-2011, 02:43 AM
Samzilla's Avatar
Samzilla
Samzilla is offline
Default Don't you wish you had one of these?
Won't put the spring on for you but might save you a lot of pain and suffering until you get home. Will also keep that kickstand from dropping in the event you break the spring whether moving or sitting at a light. I bought one for safety reasons and peace of mind. Check out the website below.
http://www.harleykickstands.com/
  #32
Old 05-28-2012, 12:32 AM
cmacclel's Avatar
cmacclel
cmacclel is offline
Thanks for the forum I just went for a 4 hour ride today with my newly purchased Road Glide and went to put the kick stand down as I pulled in to the garage and the spring popped off...........Saw this thread and pulled out a 11/16 wrench and unscrewed the top *nut* and removed the locking tab. Then rotated the kickstand forward enough to easily put the spring back through the kickstand hole them pushed the kickstand towards the back of the bike and reinstalled the locking tab and the top nut and was finished. I initially busted out the vise grips and after 15 minutes there was no way it was happening
  #33
Old 05-28-2012, 03:44 AM
Black_Hog's Avatar
Black_Hog
Black_Hog is offline
Originally Posted by Notgrownup
Mine popped off backing it out of the trailer...bought a new one for $6...TO install it back, take the top bolt out and take the little stopper. rotate the stand the opposite way , towards the fron then you can slip it back in.
That is the easiest fix. I learned that trick a very long time ago.
I just replaced my buddy's spring that way. His was stretched out and dragged the kick stand around left corners.
  #34
Old 05-28-2012, 09:24 AM
skratch's Avatar
skratch
skratch is offline
Received 4,371 Likes on 2,543 Posts
come on fellas, whats with all the bending and sticking coins/washers, etc. in....
just do it the easy way
  #35
Old 05-28-2012, 11:42 AM
frog13's Avatar
frog13
frog13 is offline
C'mon Skratch, everybody knows the manual is wrong, the manfacturer wrote it. And those guys that have been riding HD forever, and have changed many of those springs in five minutes, well we all know they don't know what they're talking about, but hey, vise grip sales might go up ........
  #36
Old 05-28-2012, 12:39 PM
Classicfc's Avatar
Classicfc
Classicfc is offline
"The worlds an imperfect place. Screws fall out all the time."
- John Bender -
  #37
Old 06-13-2012, 02:18 PM
CanuckSporty's Avatar
CanuckSporty
CanuckSporty is offline
Originally Posted by williamfrog
Remove jiffy-stand from frame piece,install spring to stand and spring frame hole,install stand back into it's frame piece. Very easy to do this way. Yes you need help or jack.
After fighting with my vise grips I came and did a search and did it this way. Worked perfect.
  #38
Old 06-13-2012, 02:58 PM
Expat1's Avatar
Expat1
Expat1 is offline
Location: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Why not carry this spring in the extended position?
Might sound stupid but it would be really nice to install it without tools and the bike resting on it's stand.
  #39
Old 06-13-2012, 07:46 PM
skratch's Avatar
skratch
skratch is offline
thats a good thought in theory, but in practice odds are that by the time you needed the spring, it would be too fatigued to go back to regular length....
i broke mine one day when i hit a pothole in a parking lot. took me all of 5 mins to change it with having one guy hold the bike up while i took the bolt out.
you might want to invest in some quality tools, if the tolerances are so far off that an 11/16 wrench fits where an 1/2 should
  #40
Old 06-13-2012, 08:32 PM
OH Bob's Avatar
OH Bob
OH Bob is offline
I like your "rolls of dimes" solution. I just spent over an hour helping a bud put on a new kickstand spring, We put his bike on a HF M/C lift, and had to remove 3 of the four bolts holding the front attachment plate for the spring, in order to have enough slack to affix the spring.
My only question is: Why didn't you provide this KISS method earlier? (:
Quick Reply: kickstand spring.
