I think I lost my “CLUNK”
You know how the Harleys “clunk” so bad when you put them in 1st gear?
Well I think I lost mine.
When I did the “SE 103 Stage IV” kit, it was recommended that I install the “SE Compensator”.
And now I don’t notice it clunking when I put it in gear. Am I nuts?
I’m still not sure what a compensator does. But my tech made a comment about how beefy it was.
Happened to me last time I had the clutch adjusted, as well as on another bike when I changed the shift linkage and did not have the length quite rite.
Been meaning to tweak mine so It will "clunk" into first (I prefer to call it "positive engagement"
I believe the clunk on initial shifting into first with a cold bike is due to clutch drag. For those that start their bike in gear have you noticed the bike pull forward when the engine first starts to crank? The clutch will drag until the initial engagement or start in gear until it breaks free. You can prove this by popping it into gear and hearing the clunk and then putting it back into neutral let out the clutch and then pull in the clutch and put it into gear and no clunk the second time. Having the clutch properly adjusted minimizes but doesn't eliminate the problem. There may be a different primary lube that minimizes the problem without allowing any clutch slip at full engagement but I don't know what it is. I may try a different one the next time I change all the fluids (maybe Amsoil). In short I don't believe the tranny lube or compensator will affect the clunk.
