Help! Wiring gurus (Dawg Maybe?)
I got my 12" PYO bagger monkey bars. Yahoo!! As others have said they are a huge PIA to wire. I passed on buying the TBW sensor without the green plug. (Yes, I know I am a dumbass). While pulling the wires the green plug literally broke apart, not disconnected, broke apart. I reassembled to try to figure out what wire colors matched and then soldered the wires. The colors don't match so I had to go with the orientation of the plug to try to figure what went with what. Not having matching wire colors is the stupidest thing I have ever seen, btw. Does anyone know the matching colors? I would like to verify. If I have it wrong I will probably buy the other sensor then pull the wires and start over but after 2 hrs of work to wire these bars I really don't want to do that.
Here is how I have it connected.
Gray sheath from the sensor
TBW sensor - Harness
White - Blue
Red - Dark Grey
Black - Black
Yellow Sheath from the sensor
TBW Sensor - Harness
Red - Red
White - Purple
Black - Lt Grey
White - Blue
Red - Dark Grey
Black - Black
Red - Red
White - Purple
Black - Lt Grey
Looks like the following according to the manual
Black/Grey to Grey
Violet/Yellow to Yellow
Red/White to Red
Black/White to Black
Blue/Green to Blue
Brown/Orange to Brown
Here is a PDF link to the wiring diagram
http://www.box.net/shared/i4q38gsz7q
Black/Grey to Grey
Red/White to Red
Blue/Green to Blue
Black/Grey to Grey
Red/White to Red
Blue/Green to Blue
Black/Grey to Grey
Red/White to Red
Blue/Green to Blue
![Icon Beerchug](https://www.hdforums.com/forum/images/smilies/icon_beerchug.gif)
I really appreciate the replies! I have a manual and can read the schematic. Mine says the same as above. Now here is the reality. I have two sheaths of wires coming out of the sensor to the green connector in the bars. One is a yellow sheath and one is a gray sheath. They both have a red, white and black wire. There is also another wire that is not connected to anything. The wires coming from the harness to the connector match the diagram blue, black, dk gray or brown, red purple, gray. What I am calling dark gray is probably brown.
So the wires don't match on both sides of the green connector.
I think I am going to just partially assemble and see what happens. I aligned based on my best guess at reassembling the switch.
here ya go
yellow sheath: black to gray
white to purple
red to red
black sheath: black to black
white to blue
red to brown
jamminjimmi
08-28-2011 11:14 AM
Geezer Glide Bob
11
09-04-2007 01:43 PM
