Tool for removing wiring pins from connectors.
I haven't checked yet and don't have the shop manual handy but it's for the connectors for the handlebar switches. I need to remove them from the connector/s to run the wiring through the new bars.
I just got finished with this very project on my 09 street glide and the handlebar swap...
I tried to use the smaller eye glass screwdriver I had but it just wasn't small enough to insert into the holes of the molex connectors to release the locking mechinism for me...I then tried a hair pin and although it would fit tightly I was able to get a couple pins removed but only after much persistence...I knew I had to find something better...I rooted around inside the tool box and stumbled on a set of welding tip cleaner files...these were of assorted round sizes and worked like a charm...I figured that they will work again on the deutsch fittings as well when and if the time comes again that I need to do something like this again...
paul
paul
