ultra tour pak on roadking
im putting a 93 ultra tour pak on an 08 rkc.my plan is to make a harnes that will go in between the harnes under the seat that runs from the bike to the tail lights.it will run out of this new plug to the tour pak with another plug that will hook into the tour pak.has any body else done this?any other ideas out there?do yo think 18 ga wire will be heavy enough?once in the tour pak i might put a cigaret lighter.for charging phones and other stuff.this would be conected to the tail light wire.so it would only be hot while lights are on.thanks for any help you can provide.
yea i got mine off ebay to.figured id save some money.by the time i bought hd paint clear fiber glas kit a lock body filler i could have just bought a new one.there are wires inside the pak.ill end up redoing thosetoo guy had a switch wired into th e tail light wire.not sur why.im wodering if 18 ga wire will be heavey enough.and mine is on a detachable rack so id like to be able to unplug it for easy removal.
The cleanest installation is to use a Deutsch connector under the seat to mate with the Accessory connector there to pick-up the ground, run, and brake light circuits. You'll need a socket housing (p/n 72114-94BK); socket lock (p/n 72154-94); and, three socket terminals (p/n 72191-94). That's the "front" end of your new harness.
The "back" end of the harness to connect to the tour pak will use the same parts HD uses for the tour pak harness found on fairing models. Use the part nos. in the Touring parts catalog for 2008 Touring models, although it's probably the same for earlier years since HD seldom changes connectors from year to year. The p/n's are: 73153-96BK (socket housing) and 73191-96 (contact socket--need 3).
Using the Accessory connector under the seat is how HD wires a number of lighting accessories such as the tour pak spoiler LED and saddlebag spoiler LED accessories.
Good luck with your project.
Carl
PS: 18ga. wire will be fine.
Carl
riteway
08-26-2010 03:39 PM
