2008 FLHRC Hardware Docking Kit
Old 07-01-2010, 11:22 AM
Kiowa Driver's Avatar
Kiowa Driver
Kiowa Driver is offline
Default 2008 FLHRC Hardware Docking Kit
I am a little confused to say the least. First off, I have a Mustang Solo with a detachable rear seat. I ride with just the solo seat a majority of the time and would like to mount a solo luggage rack. I'd also like to have the option of mounting a sissy bar and a two-up luggage rack for when the rear seat is on for long trips. Finally, I'd also like to be able to make all of these swaps in a minimum of time. Is this possible, and if so, which docking kit or kits am I going to need? I believe I'll need two separate ones, will they both be installed simultaneously or do those have to be swapped out as well? I appreciate your responses ahead of time.
Old 07-01-2010, 05:25 PM
NMRoadking09's Avatar
NMRoadking09
NMRoadking09 is offline
Im not positive but I think the 4 point docking kit will work for all of the above. You may have to check with a dealer. If you find anything out let me know. I have the 4 point but want to add a solo like you have. Thanks.
Old 07-01-2010, 06:38 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
4 point docking kit is for 09 and later, but yes the 4 point would do both. He has an 08. The docking kit that is needed is 58304-06. HERE is a docking hardware kit matrix
Old 07-01-2010, 07:37 PM
Kiowa Driver
Ok, so just to clarify, in order to mount:
Sissy Bar w/ 2-Up Luggage Rack (PN: 53341-97A)
https://www.hdforums.com/forum/attac...1&d=1278030558
and
Solo Luggage Rack (PN: 53048-06)
the only Docking Kit I need is PN: 58304-06?
I'm not in love with the Sissy Bar/Luggage Rack combo, based solely on looks, but am trying to make this setup as simple as possible. If I went with a separate sissy bar and luggage rack would I still only need the one kit?
Attached Thumbnails 2008 FLHRC Hardware Docking Kit-53048-06-solo-luggage-rack.jpg   2008 FLHRC Hardware Docking Kit-53341-97a-sissy-bar-2-up-luggage.jpg
Old 07-01-2010, 07:50 PM
dawg's Avatar
dawg
dawg is offline
53341-97A is not a detachable accessory. 53048-06 is a detachable accessory, and if only using that one you'd need 58303-06. If you want to be able to swap between solo and two up detachable accessories such as a sissy bar and a tour pak, just get the 58304-06 and be done with it.
Old 07-01-2010, 08:18 PM
Kiowa Driver
Thanks a lot!
Bibber48
11-18-2012 08:35 AM
ghostflamed
Touring Parts
10-02-2012 01:12 PM
Ultrachris
03-04-2011 11:40 PM
skim1420
07-05-2009 08:10 PM
Nadil
09-15-2006 11:10 AM
Quick Reply: 2008 FLHRC Hardware Docking Kit
