Help with a gas leak on a Evo CV carb
What is the fix for the plastic 90 degree fitting coming out of the carb? This plastic fitting is cracked and leaking. Is this fitting replaceable or do you have to replace the whole carb? The service manual does not list this as a separate part. I am sure this is not the first one of these fittings to break.
This should do it.
http://www.harley-performance.com/fuel-max-inlet.html
I've seen these in different brands and prices also.
Mick
Mick
