Fairing lighter
Old 07-05-2010 | 10:28 AM
rushbass's Avatar
rushbass
No problems here using my cig lighter port to power a Garmin GPS, or recharge a cell phone... just make sure your power adapter you are using does not hit the tank when in a full-locked turn to the left.
  #32
Old 07-07-2010 | 08:50 AM
mbrownls1's Avatar
mbrownls1
Stage III
a gps or other plug will compress the spring clip that retains the lighter, if you use any divice in the lighter socket, you will need to reset the spring clip or you will loose your lighter, its easy to do, but you MUST either disconnect the battery or use an insulated tool to reach in and pry the spring clip up so as to put the tension back on the lighter.
Betteroff
2014-2023 Touring Models
06-09-2014 07:59 AM
mathew2172
03-15-2013 07:00 PM
2010 ultra man
04-14-2010 09:31 PM
buckwheat
06-13-2009 12:17 AM
osolow
06-09-2008 02:14 PM
Quick Reply: Fairing lighter
