Fairing lighter
Old 06-28-2010 | 10:25 PM
vzts4q's Avatar
vzts4q
It also states that in the owners manual. I believe that the main reason is a saftey/cover their azz because the lawyer said so.
Another reason is because some adapters may hit the tank when the bars are full left.
Old 06-28-2010 | 10:51 PM
Pass Rider's Avatar
Pass Rider
Charge my cell phone on it all the time. Just have to be careful how I orient the plug so it doesn't hang up on the tank.
Old 06-28-2010 | 11:08 PM
DLW_FLHTC's Avatar
DLW_FLHTC
I have had my Zumo 550 plugged into it for 3 years not problems.
Old 06-28-2010 | 11:45 PM
hougz79's Avatar
hougz79
I have only used it at times as an iPhone charger, but no issues.
Old 06-29-2010 | 08:29 AM
nvsteve's Avatar
nvsteve
Originally Posted by Iceman24
I power my mini air compressor for pumping up tubes & tires - no problems. I believe Zimbob's got the right picture...dealer wants to sell you their unnecessary option.
Same here. As a test I filled my front tire from empty to see if the compressor would handle it. No problem.
Old 06-29-2010 | 09:10 AM
audettd's Avatar
audettd
I thought it had something to do with the warranty....if you used something other then the lighter to power up and it caught fire or something like that they wouldn't cover it. As long as you have a fuse between the unit and the lighter I would think everything would be fine. I've used mine for a quick phone charge while traveling. I had my GPS mount hardwired so there was no need to use the lighter. I wouldn't hesitate using it though (I don't smoke)
Old 06-29-2010 | 11:43 AM
FLS2FLH's Avatar
FLS2FLH
Originally Posted by 2010 ultra man
I think what the stealer meant is once you plug in your gps or whatever it bends the prongs in on the inside. I thought b.s. too till i watched my lighter fall out and bounce down the interstate.Just my 2cents.
Mine fell out and bounced down the interstate without anything else ever being plugged into it.
Generally speaking, the heating element in a lighter draws way more current than a GPS or a cell phone. I power my GPS off the back of the lighter - hardwired inside the fairing - no issue at all.
I'm considering getting one of those LED flashlights as a replacement for my lighter, but not sure it wouldn't meet the same fate as the lighter did.
Old 06-29-2010 | 11:45 AM
NoBoldRider's Avatar
NoBoldRider
!We have a winner! The dealer is just following the Moco's stance.
Old 06-29-2010 | 12:58 PM
cbears's Avatar
cbears
Originally Posted by gtrplyr
Quick question: I was told by my dealer that the lighter in the fairing of my 09 FLHT is not made to power anything (ie., phone, gps. etc), but is only to be used as a lighter. Something about not being strong enough. He said that if I want to use a gps, that will have to get an upgraded lighter. Sounds strange to me but I thought I would ask... I don't see any reason why I can't plug a gps into the fairing lighter. Anyone know if this is true?
Thanks in advance.
Gotta call BS on that one. I have my GPS plugged into mine all the time.
Old 06-29-2010 | 01:10 PM
jsimo7's Avatar
jsimo7
I have my GPS and Sat Radio hard wired to the back of the lighter. It has been running both for 2 yrs and 34k miles no problems. The lighter circuit has a 15amp fuse in the fuse block. The inline fuses to the GPS and Sat Radio are 1 amp each. It works for me.
Quick Reply: Fairing lighter
