What is the rise of stock FLHX bars.
I have http://www.khromewerks.com/
Sweepers on mine +2 which would make them 10" rise?
-300514 -300515 not sure which I bought now?
Used the same wire no extension needed on the throttle.
Used clutch cable - 38649-08
No brake line extension needed.
But I am thinking of getting the next higher ones:
300315 = 12" rise
The wire extensions I know what to get.
The clutch cable in black I'm not so sure.
And I have to get a brake line extension to the front brake T? - Not sure there either.
300315 = 12" rise
300315 = 12" rise
The clutch cable in black I'm not so sure of what to get?.
300315 = 12" rise
Found some info:
Barnet take the stock part numbers and then all you have to do is add the plus size (+6" for example) to the end of the part number.
Clutch Cable: 101-30-10046
Front Brake Line: 213-30-13091
http://www.barnettclutches.com/
If you go with 12" rise, you will not need the wire extensions. I didn't need them for my 13" I just routed the wire under the radio and it worked fine. Barnett sells black clutch cable and Goodridge sell black brake lines. Try hdbikeparts.com for the cables and lines. Just tell Johnny what you are doing and what you need and he can help out. Good guy. He will also help answer any questions along the way if you install yourself
