Engine Turning Aluminum?
RE: Engine Turning Aluminum?
There are turning brushs available from Brownell's,(on line at brownells.com) they are for guns, and are small, you can go simple with a dremel tool and small buffing wheels and a abrasive compound like heavy rubbing compound, ive done a lot on steel, should be simple on alum. Also those little abrasive geen 3m pads can be cut into circles and glued to a small sanding disc and used. but practice on a scrap piece first.
jluvs2ride
04-06-2013 08:42 PM
