If you make a play list in itunes then click on the playlist and it will open . in the bottom right corner it says burn disc and then opens up to option to burn regular , data or mp3's . I burned this way and it worked on my 09 Street Glide
Yep-- works for me too using the MP3 format, although I change the burn speed to x2 or x4.
I find if I do this the burned CD doesn't occasionaly skip, and it seems the CD sound quality is a little bit better as well, but I'm lsitening with older ears anyway.
