Saddle Bag Latch Spring Install
Gentlemen, One of my saddlebag latches has been floppy so I decided to change the corroded and broken latch springs on both bags. I don't intend for this to be a "How To" thread but just want to pass info and pictures on "How to do it" minus the details. The PDF for step-by-step instructions is located here.
http://www.harley-davidson.com/en_US...ts/-J02671.pdf
The kit and associated part numbers depicted below. Don't know how much they cost, I traded my brother in law a few bottles of Soju for them. $10 in Soju.
Follow the PDF directions and you should have the lids off in no time. It's good if you have a buddy to hold onto the lid while you unbolt everything. I laid everything out on the kitchen table.
The broken spring. These things really corrode. One spring was busted and the other was ready to break. Nothing else was rusted, just the springs.
The hardest part was prying open the end of the hinge to free up room for the pin to slide out. Take your time and work slowly, it will open up. Use a flat head screw driver as shown in the PDF instructions.
Before you know it, you have new springs installed. Make sure you install them so they look like this.
End result: saddle bag lid latches that snap in place like they were new. Remarkable difference.
This is a pretty easy job so grab a cold one and get it done. And for you Master Mechanics who have been doing this for years, I didn't know how to do this so hopefully this post will help someone.
The following 3 users liked this post by Kilo6:
This place is great!! A few days ago I realized that one of my saddlebag lids was all sloppy. Further investigation revealed the little f***ing spring was broken. I just assumed that I would now have to live with that. Had a flash and typed it into the forum and viola!! With the above pictures and the official instruction sheet I just finished changing both springs with very little trouble and only pinched myself once. It did take me a few minutes to realize I had to "heave around" on the spring and twist it into position while sliding the pin back in. I also put a dab of lithium grease on each one to try and keep them from corroding. Just in time for our second annual group ride to the U.P.
Thanks guys!
Thanks guys!
