Strange Noise
08-23-2006 | 07:47 PM
Strange Noise
I have an 03 Road King Classic, a couple of weeks ago I started noticing a chirping sound when the bike is running at slower speeds, or going from higher speeds and let off the gas to start slowing down. The sound is coming from behind me....anyone have an idea what it is. It is starting to become more frequent.
Thanks
Kevin
08-23-2006 | 07:53 PM
RE: Strange Noise
Sounds like a loose drive belt.
08-23-2006 | 07:56 PM
RE: Strange Noise
Maybe you have a bird in your backpack?
08-23-2006 | 08:24 PM
RE: Strange Noise
belt is rubbing belt guard.
08-23-2006 | 09:09 PM
RE: Strange Noise
Check the intake manifold gaskets..........I know it sounds odd, but if I recall, a friend had the same experience and that's what the culprit was.
08-23-2006 | 09:16 PM
RE: Strange Noise
Quote:
ORIGINAL: sliderking
I reaalize you said it was coming from behind you but, I had a similar instance and the chirping sound was that the throttle cable needed tightening...
08-23-2006 | 09:31 PM
RE: Strange Noise
Loose exhaust baffle, perhaps?
08-23-2006 | 09:44 PM
RE: Strange Noise
Check the rubber mounts that hold the exhaust just below the saddle bags. Sometimes they require some silicone.
08-23-2006 | 10:42 PM
RE: Strange Noise
Check the belt for proper tension, and make sure it is clean.
doo925
06-03-2018 07:30 PM
94 Heritage
08-08-2008 10:04 AM
94 Heritage
05-15-2007 09:24 AM
BadBobOk
04-25-2007 12:12 AM
mikehennin
05-04-2006 04:39 PM
