HD Dual Bulb Headlight
RE: HD Dual Bulb Headlight
On the day I picked up my bike and started looking her over I noticed a problem.
The headlight adjustment for up/down on my '06 RK Classic was busted. The screw you turn screws into a plastic bracket which is riveted to the metal headlight housing. The rivets on my plastic bracket had given way and I only had one adjustment - aimed 6' in front of the bike. Two pop rivets later and all is well.
You might check this if you can't get the light to adjust.
Edmo
Edmo
ORIGINAL: speeder75
...Also seems to be pointed to low....
Its the 4300. Thats the brightest/whitest light. And yes it the 2 bulb Harley light. Heres a couple of shots of where I mounted the ballast and transformer. One on each side of the brackets of either side of the radio. I think the hardest part of the install was snaking the power wire under the tank.
[IMG]local://upfiles/1197/F0771BC30F5E4C56A8D716AF09F91525.jpg[/IMG]
[IMG]local://upfiles/1197/02207E28A6C24DDABC485A1D88CFFD14.jpg[/IMG]
ORIGINAL: SLORider
To 05 ULTRA-
is that the 4300, 6500 or the 8000 one?
Also confirming you installed that in the 2 bulb Harley headlight?
Where did you install the ballast/transformer box?
Thanks,
Getting old also, am over it.
jb
To 05 ULTRA-
Thanks,
jb
I'd get the H11 first and see if you think you'll need the high beam. It just barely makes a small spot in the middle of the low beams patteren. Only time I use it is to power up the garage door opener now. LOL
But let us know how it works if you go for it. Never too much light I guess.[sm=smiley16.gif]
I haven't tried it yet but the stock H11 can be put in the high beams location with a little dremel work on the bulbs key. Maybe the next time I have the fairing off....
You can also replace the H11 with an H9 as per Daniel Stern
55 verses 65 watts = more light
ORIGINAL: BigTom
I bought this light too and had the same thoughts. I will be getting a HID kit for the H11 low beam and a kit for the H8 high beam and really light up the road.
PIAA and a few (very few) others have H11s. Silverstar isn't one of them. Hers a few who do.
HOEN
Sylvania
Daniel Stern
One of the biggest down side to this new light (besides it sux) is that you can't readily find replacement bulbs. Another reason I swapped out to the HID bulb. You guys that opt to keep the stock bulb remember to get a spare if your doing any touring. You wont find them at the local auto parts store in West Bumbeldump Arkansas.
HOEN
Sylvania
Daniel Stern
ORIGINAL: speeder75
I presume they are the best ?? I have heard good things about Piaa also...Do you think these will help ?? Where is the best place to buy bulbs ?? I don't even know what model bulbs i need. I am very close to just putting the stock light back on. THANKS
