2009 Road glide shocks
The shocks might look the same but might have different specs. That is why there are different part numbers. You need to follow the shock air requirements for that year model.
Also, if you changed to longer shocks, which I did, you need to change the drive belt tension. The belt needs to be looser with longer shocks. This is explained in the repair manual and this thread: https://www.hdforums.com/forum/touri...rive-belt.html
sportsterleroy
03-20-2011 11:18 AM
