Fork Oil Replacement
RE: Fork Oil Replacement
Why? , i just refilled through the drain holes on my RG, Dennis Kirk sells a hose and fitting for the job. I used a two ounce syringe to fill with, ya have to be quick when you remove the tube and replace the drain plug.
Unless there is something different on the UC that i`m not aware of.
You can do it very easily on older bikes with air forks. You'll need a vacuum source, the cheapest route for that being a Harbor Freight venturi vacuum attachment for an air compressor, about $10. You connect it to your air compressor regulated to ~20#. You'll need to rig some plastic tubing to fit on the valve housing for the air forks. The forks have a recess around the drain-plug hole that fits a 1/4" OD plastic tube.
1. Drain fluid from one fork.
2. Place proper amount of fork oil into a small container. Mine is 7.5 oz., wet.
3. Remove valve mechanism from front air-shock valve housing.
4. Attach the vacuum source.
5. Attach the filler tube to the fork filler hole, the other end emersed in the clean fluid.
6. The vacuum source will suck the fluid into the fork and keep it there as long as there is a vacuum.
7. When all the fluid is in the fork, replace the screw and quickly disconnect the vacuum source. The HD service manual emphasizes not to allow the vacuum source to stay connected longer than necessary.
8. Repeat on second fork.
This procedure takes me about 15 min. and is outlined in the service manual, at least it is for my 1996 manual.
hawkmaneg
03-23-2010 12:10 PM
