looking for amp
For ease of install I'd recommend the J&M amp as it comes with a mounting plate and most wires connected. If you want to save a couple bucks and wire yourself with splicing and such, we carry they Elf amp as well which is pretty much the same without the mounting plate or wiring kit.
http://www.phatperformanceparts.com/...mp-250hc06.htm
http://www.phatperformanceparts.com/...f_p/e2125x.htm
if you have some skill and you dont want to get ripped for an expensive amp read this thread, works great
https://www.hdforums.com/forum/elect...-09-ultra.html
Make sure which ever one you buy is compatible with the 8ohm speakers on your 05, most are set up to run 2 or 4ohm speakers. I checked, because I wanted to try the J&M 7.25s without an amp, but found out that they weren't recommended with the J&M amp if I felt I needed more power down the road.
