Plasma Rods
#141
I got the 8".... I measured my filler panels, and it looked like 8" was the right fit for me. I would say just measure where you are putting them, and see what you have room for.....
14 FLHX has a bunch of great pics for his Street Glide set up - here are a couple pics of my Road King with filler panels set up....
I would have liked to gone with 10" or 12".... but you can see, there was just no room to do that.....
#142
Thanks guys.....
Looks great man.
#144
Looks awesome. I bought them also along with the LED blinkers from C.D. and they are still sitting in my garage. Have to get them installed.
This weekend I installed a set of red plasma rods on my SG. I wound up mounting them in a little different way and I believe it gave them more visibility. The plasma rods for those who haven't seen them are 8" long LED's. They come in Red and Amber and 2 or 3 wire configurations. The LED itself is smoke colored so it is actually hard to see when it's not lit up. I chose the red lights because I was only going to use them as stop lights and in the 2 wire configuration. If you have any sort of tail light module on your bike you must install these before the module. The part here where I made the change in mounting was the use of vinyl 3/4 corner round molding from my local Lowes home center. The plasma rods are mounted using double sided tape. The SG facia has an inside radius. If you mount the plasma rod on the inside of the fascia the LED faces the back of the saddle bag and the amount of LED that is viewable is very limited. Plus the gluing surface is very limited. If you use the corner round molding with double sided tape it fits perfectly in the radius on the back side of the fascia and the normal side of the molding that usual sits against the wall now presents a nice flat surface to double side tape the Plasma Rod to. The vinyl molding sticks great too. This gives it plenty of sticking surface and the LED presents itself perfectly now with alot of visibility in the rear when it's lit. Like I said they are almost invisible between the bags and in my case only light up as a brake light. Mounted like this they are very visible even in direct sunlight.
Plasma Rods are a product of Custom Dynamics.
#145
daharleyrdr
Good Or Bad Shopping Experiences At HDF
09-18-2007 09:45 AM
