so confused PCV with AT
I don't think my auto tune is working my gas mileage sucks! performance is down. when I hook the PCV to my PC after a run there are no trims in the auto tune section am I suppose to see what the trims were after a ride, am I suppose to? In the ingnition tables there is all 0's. I also have some isues with hard starts and some back fireing through the TB. help meI am leaving on a 3000mi trip in a week I would like to get this resolved before this.
If the table sare all 0's I would say that your tune is not in there. I would call FM and see what the deal is. From my understanding you still should have a tune there the auto tune just modifies it as you ride according to what all the factors are. Try to go to get map and see if you can't find the map for the bike and then send it to the PCV. Should get you back up and running.
Let us know, as this type of thing is usually something simple.
Fuel Moto maps tend to be tuned for cooling and performance at the expense of gas mileage, but you can have the mileage and performance by some tweaking. The trade-off to better mileage is typically heat, so you'll have to be the judge where the sweet-spot is for you. I have mine set very lean (near stock) in the cruise-range and I'm having no heat issues, but I have an oil-cooler which helps greatly to keep peak engine temperatures at a sane level. I get 48-49mpg on the backroads using E10 gas, but city mileage is usually in the upper-30's and I have not found a way to increase it there. What kind of mileage are you getting?
I am getting in the low to mid 30's in gas mileage before mods I was getting in the low to mid 50's my concern is that after a ride I have no trims ton accept or clear so I don't think how I set my AFR's. Today I have set my target AFR's in the 4.2 range in my crusing range but I don't think my AT is working
Have you enabled the Auto Tune in the software? Made sure that the map switch is off. Make sure that the enable hardwae swithc is off. Make sure in the software that the max inrichment and enleanment have a number in the 20 is the normal. You will want to ugrade to the new software 1.0.3.3 and the new firware 1.4.0 then update the firmware to the device. If all is wired ccorrectly then software is probably not set up correct.
