so confused PCV with AT
You had the Hardware switch enabled with no switch installed to close the circuit, that is why it worked when you installed a jumper
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
If you are not getting fuel trims the Auto Tune is not installed incorrectly. Make you have enabled the Auto Tune in the software, you do not need a switch however if you have installed one make sure you have it wired correctly. The most common install mixup we see during the install is that users forget to install the CAN termination plug in the open port of the the Auto Tune module, it is the black plastic plug (not the rubber dust plug) which contains a resistor and it is required to complete the CAN circuit. The other mixup we see is that the AT is plugged into the ACC port under the seat, the AT needs to be plugged into the diagnostic plug under the left side cover on 08 and newer Touring models and is under the right cover on 07 and earlier bikes. To verify the AT is working properly you can plug into the software, start the bike and you will be able to see live AFR for the front and rear cylinders.
Don't feel too bad, as this is a common omission. I did it too back in Jan. '09 when they first came out, but I understand DJ is now putting a warning in bold letters in the instruction manual. There was none way back when I did the upgrade, and the only mention of it was the diagram in the instructions. I think DJ should install these things at the factory and there would be fewer problems like this.
Ok I think I am up and going now ended up calling Fuelmoto they walked me through it. Thanks to everyone for your help. Now that I have trims that I can see what do you do with the numbers that I see? Is it usual for the front & rear to be differnt? How can I build a complete bike and be so clueless when it comes to electrical & programers?
