I have a stock 07. I want to put a set of rims from an 09 ultra. I have a rear swing arm available from an 09 ultra. Seller says it still won't work, but can't explain why. Help me out here and can some ome fill in the gaps. thanks
Going to need more than a swingarm. Will basically need the whole rear end of the bike. Wider fender, bumpers, etc. If you have access to an 09 swing arm. I believe if you do some comparsion between the 09 and 07 swing arm. You will see some differences that will make it not just be swapping swing arms.
