2000 roadking oil pan
If the cam chain tensioners have not been upgraded to the hydraulic system, then you can (and should) do the oil pump when you do the cam chain stuff. If this hasn't been done yet, do it NOW!
I have no idea what an "oil pan insert" is. Actually, this is the first I ever knew their was an "oil pan" on my bikes. The sump, I knew about...
