Removing the CAT from Header????
OK, I did a search and found a lot of talk but no real How To on removing the cat from the pipes.
I have a 2010 RG, I bought a 2010 header system from a Ultra and plan on removing the cat and installing two mufflers ( have those also). I just don't like the 2 into 1 look and want dual mufflers.
So my questions is....what's the best or good method of removing the cat material? I plan on taking the header to a machine shop and have them slice the area of the cat in two so I can access the blockage.
Now after that, what's the best way to remove the material?
Drill it out? Air hammer? Hole saw? Grinder?
Pictures would be a big plus....
Oh I'm keeping my stock exhaust just to be safe and if the Feds start testing....I'll have my stock setup as a backup.
Fullsac Performance use to remove the cat material for $100. They don't advertise that service on there website any more. I understand they have an X pipe now that replaces the section that has the cat material in it.
Might call and talk to Fullsac Performance.
When they were removing the Cat material from the 09/10 head pipes. They did just like in the pictures above. They cut that section of the pipe in two sections. Removed the material and then welded it back together.
David
David
today i just bring my 09 sg in to my friends shop
he grind the header and starting heat the cat with weld and they remove the cat
after finish he weld back the header
first impression is exhaust sound....my ribehart sound like what a rinehart should sound...its getting louder and real hd sound
the power of the bike is a lot bigger ....more responsive....
im sure i can feel the power improvement easily
i recommend to do the gut of the cat
Another option is this. Just saw it in a mag. http://www.namzcustomcycleproducts.com/new.html To bad you got a 2010 header though.You would need a non cali. 09 headpipe.
