Biketronics stereo problem
I have a Biketronics kit in my 09 FLHT. Was working great but when I got the bike back from the shop last week the clock was reset. Figured that they either unplugged it or disconnected the battery so I didn't think much about it. A week went by and I went to turn on some tunes and the stereo is unresponsive. Now the handlebar controls will turn the radio on, switch between sources (CD, tuner, USB), skip/rewind songs, and adjust the volume, but the face-plate of the radio will not work at all except the "off" button. I have tried everything (disconnected the stereo and reconnected it, disconnected the negative battery wire for 15 minutes, pushed the reset button), but nothing works. I asked the co-owner of the shop that worked on my bike but he said they didn't touch the radio. Was gonna call BT in the morning but thought someone here may have encountered this before. The head-unit is Sony CDX-640UI.
Thanks for the help.
Did you figure anything out? I have exactly the same problem after I changed to a different satellite antena. I didn't bother testing the setup since it was only an antena exchange. However, I did wash the bike after I put everything back together. I'm wondering if I got some water in the face? Supposed to be a marine radio - wtf?
iam now on my second radio from Biketronics and having the same problems with it. Both radios would work great for a while then start to act up. None of the controls work right, i cannot shut the radio off, hates water, blah blah blah. I have called Biketronics and they are helpful but never really addressed the problem to resolution. As far as getting wet, if they sell a radio for a bike, marine or therwise, it should be able to withstand water. I have given up on the tunes. If it works it works, if not, oh well.
I don't know which radios you have that have problems, but I had a Biketronics/Sony set-up on my bike for 4+ years without any problems and the bike got drenched in heavy rains while parked more times than I can remember.
As for the DIN-size "marine" head units, the only thing different about them is a coated circuit board--the faceplates are the same as non-marine versions--at least those from most vendors.
The only maintenance I did on my Sony head unit was to occassionally wipe the contacts on the unit and faceplate with a Q-tip dipped in alcohol.
Carl
Carl
I have a BT/Sony setup and the only issue I have had is the radio constantly runs through its setup program while I am riding. Doesn't affect the function one bit, just will switch from bass-treb-front-back-ect. BT checked my module out 2 winters ago and said it had to be an issue with the controls on the bike. I just don't worry about it anymore. Bryan
