o7 electraglide low idle what is the fix?
not all the time but sometimes i will get a low idle after a run on the highway the idle will be around 700rpm sometimes it will last for the day sometimes two then it goes away, i have a pc5 on the bike but it does it without also.
anybody know what the fix is? thank`s Bill
I'm running into the exact same problem. Doesn't happen all the time, but after running on the hwy, coming to a stop, the idle drops low, voltage drops low, then after the bike comes to a complete stop, the idle and voltage comes back up and then is fine. I changed out the TPS (throttle position sensor) and it doesn't do it as often. I've heard that there's a new download for the ECM that helps with this idle problem but I haven't had a chance to deal with that yet. Anyone else have this issue?
Email me here and I'll send you TT410, which addresses this issue in '07s.
