Lazy oil change
#61
Any thoughts
Beary
#62
http://*******.com/2d33h2s
http://www.jpcycles.com/product/910-439?utm_source=google&utm_medium=organic&utm_campa ign=products
Tell me more about your method of removing the spark plugs and cranking the engine to get more dirty oil out of it. How much oil do you get this way? How long do you do this without risking to damage the motor and how do you catch the oil out of the plug holes?
I'm thinking of using the Scavenger oil kit from Rogue Chopper. It uses 1qt of fresh oil to push the old one out of the crankcase, which seems a safer method to me, mechanically speaking, plus you don't make a mess since the additional oil comes out of the drain hole.
http://www.roguechopper.com/
#63
Now what does releasing the compression mean?
#64
Beary
#65
IT means taking the pressure off the crank and bearings mostly. There is a thin film of oil between the two parts and if there is not oil pressure during the compression, the thin film will not be enough to prevent metal to metal contact. Taking away the compression might be enough to keep enough film to protect the parts.
Beary
Beary
#66
My routine is to go to the end of my road, hang a right and give it good hard ride once around the block to warm it up. But then, going around my block is about 20 miles. Just seems to make sense to warm it up first.
Dawg makes a good point about the dealer. When you check your bike in for a service the next day, there is no friggn way that the tech takes your bike for a 20 minute (or more) ride to "warm it up to normal operating temperature" before the oil change. As a matter of fact, I think it would be good marketing technique for a dealer to advertise actually use an oil scavenging system.
All in all, I'm a believer in heating up the pig if possible.
#67
Harley had it right on the 1930-1936 flat heads. Motor never ran on old oil...after your bike started smoking some you simply pulled over to the side of the road and could drain the engine oil on the ground and then refill the motor from the on bike reservoir of new oil and you were good for another 500 miles.
#68
#69
BobRR
07-23-2022 02:28 PM
dFREDb
12-23-2009 03:01 PM
