Lazy oil change
Old 06-03-2010, 05:27 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Just drain it and don't worry about it. The sky won't fall.
Old 06-03-2010, 05:28 PM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
Wink
Originally Posted by sgdiesel
I am intrigued by the thought process here, why is it any more effort to get the oil to temp? It flows better and hence drains better at temp.
I would guess it took more effort and longer to make the opening post than to warm the oil!
No only took about a min to ask the question. But thanks for helping
Old 06-03-2010, 05:31 PM
jackinthebox
Originally Posted by dawg
Does that mean that when a customer drops his/her bike off at the dealer in the evening for a 1k, 10k, etc. check for the following morning that a tech actually rides the bike 20+ minutes prior to bringing it in and changing the fluids? Just sayin.
You know I was thinking the same thing but didn't want to start a my stearler sucks thread too since I was asking an oil question and I know oil threads can get out of hand
Old 06-03-2010, 06:19 PM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
Hell, if you're feelin' that lazy, don't change it at all. Wait until a day when you're feelin' a bit more energetic!
Old 06-03-2010, 06:27 PM
lowriderbob's Avatar
lowriderbob
lowriderbob is offline
No matter how hot you get the oil there will always be a small amount of oil left in the oil pump/cam assembly and if you have a oill cooler there will be oil left in it as well. So go ahead get it real hot so it burns your fingers and you drop the drain plug into your oil catch pan!
Old 06-03-2010, 06:44 PM
'05Train's Avatar
'05Train
'05Train is offline
Oh noes! Then my fingers might get dirty!
Old 06-03-2010, 07:28 PM
2WheelGlider's Avatar
2WheelGlider
2WheelGlider is offline
Getting your fingers burnt when the plug falls into the pan of 275 degree oil is part of the experiance. I dont know what I'd do if that didnt happen...LOL
Old 06-03-2010, 07:38 PM
shortride's Avatar
shortride
shortride is offline
I did another oil change in all 3 holes today. I change oil every 3k miles in the summertime and 3500 to 4,000 in cool weather.
Old 06-03-2010, 08:09 PM
Streetrunner's Avatar
Streetrunner
Streetrunner is offline
I change my oil like the dealer, ice cold. I measure the oil that comes out, it's all there. As far as moisture and contaminants, if any, I think they are in the oil. I just don't want to deal with a hot motor. Not worth the burn.
I believe that no matter which way you choose to do it there will be no effect on the longevity of the motor. The main thing is simply to keep it fresh by changing it at recommended intervals.
Old 06-03-2010, 08:48 PM
davessworks's Avatar
davessworks
davessworks is offline
well there was a time when you'd better get the oil from the engine into the right place (tank) before draining - esp. on a Softail.
Quick Reply: Lazy oil change
