Any one have a carb any more
Looking to tune my 2002 EGC carbed. Already have the scream eagle slip ons. I'm geetin a little sneeze from carb and wondering do i need to upgrade the a/c and rejet carb or just live wth it. i'm lookin at the CV Performance tuner kit http://cv-performance.com/index.php?...od&productId=3 and K & N A/C kit 3909. any thoughts ????
Thanks for all the tips. looks like I'll be tinkerin with the carb. beats the darn maps and dyno's needed on the EFI.
so do i really need to stage 1 the air filter for $100+ or just jet and fine tune the stock carb. i did buy the CV Performance kit. guess it can't hurt and was only a 1/2 of bean.
Nothing wrong with a Mikuni - I've had several. But on a basically stock bike the CV will run just fine with a few tweaks mentioned previously. If you go with a Mikuni you'll still have to dial it in.
Also DynoJet makes a jet kit that includes an adjustable needle and shims so you can dial her right in. I've done 'em both ways with great results.
My 05 springer is carbed.It was getting about 52 miles to the gallon! It was way lean with the opened a/c and Screamin Eagle slip ons.It would sneeze and cough.I took the cap off the air fuel mixture adjustment,turned it out 3 turns and put the Sportster needle in.Man what a difference,the only time it sneezes now is if I forget to turn on the fuel! My mileage dropped to 42 mpg but it runs great!
blair
10-09-2011 07:11 PM
